Hello all. Apologies in advance if I'm breaking any rules by creating a thread so early on in my membership. I've searched the forum for this information (as well as the greater web) but haven't seen this discussed anywhere else.
I would like to mention a phenomenon I've noticed while detailing Toyotas in particular. On newer Toyota vehicles (including my own!) it seems that the exterior surface of side and rear windows either have:
1. A very bad case of water spotting that isn't visible to the naked eye while dry. Possibly induced by where the glass is stored at the factory, or due to rail transport or sitting on a dealership lot.
2. A film (intentionally applied by the OEM?) that makes it appear that the glass is etched with spots. Perhaps this film provides UV protection or is meant to minimize the chances of more severe mineral-based spotting.
The spotting is easily noticed while the glass is wet. Once the moisture has evaporated, the glass appears to be perfectly clean and spotless. I've even gone as far as running a brand new blade across the glass to determine if any sort of film would come up, but nothing was found.
To demonstrate, I have taken some pictures that show what I'm describing.
This first set shows a side window that has been wiped down with a wet microfiber towel that was fairly damp. The moisture left on the glass is 'sticking" to a pattern of spots. If you leave the glass fairly damp and allow it to air dry, you'll notice random spotting.
This next set shows an adjacent side window where I polished the glass with a PC, light cutting pad, and some Duragloss glass polish. To ensure that I'm not representing any properties of the polish, the glass was wiped down with alcohol. You can see where my "swipe" pattern is from the towel I used. No pattern or film is noticed.
I almost suspect this is a film of sorts because the "pattern" is even noticeable on the edge of the glass that normally sits inside the window channel. In other words, if this was externally induced water spotting, how on earth would it manage to creep under the weather strip?
Does anyone here have any thoughts?
