Tree sap!!! How to remove it?!?!
chris.ganucheau
Like the title says I was washing an waxing a car an my car was on the street under a tree (whole street is covered with trees) an this morning I saw I have a tree sap drip on my passenger door. Any help?!?!?
There's all kinds of trees and bushes and each tree or bush emits it's own type of sap. Some sap is water soluble and can be easily softened, dissolved and removed just by washing the car. Some tree sap is like epoxy glue after it dries and hardens making it difficult and risky to remove.
If you haven't tried washing, try that first. You also might consider finding a way to keep a wet towel on top of the tree sap to hold water against it over time to soften the sap.
I show that technique here for removing a dried bird dropping safely but you could use the same principal for dried tree sap, you just have to figure out how to keep the towel against a vertical panel. A long beach towel might do the trick, affix it onto a horizontal panel somehow so the rest of the towel rests against the vertical panel.
How to safely remove a dried bird dropping
:xyxthumbs:
Appreciate the quick response! I haven't tried washing yet, only noticed it today on my way out the door to head to work. I just decided to ask because I have heard of tons of different ways to remove it (ex: WD40 not sure I would try it though). I don't have trees at my house, I was washing someone else's car to make some dough! :dblthumb2:
It's more than washing for some tree sap, it's saturating the sap with water to soften it, a quick spray from a hose nozzle won't work because all the water will simply run off a vertical panel, so check out the links to the threads I included, the pictures tell the story.
Also, better to get on top of this as soon as possible, before the paint can become stained or the tree sap solidifies like concrete.
If you're already at work, try to find a place to park so the affected area is in the shade, not full sun.
:thankyousign:You got me worried about it hurting my paint lol, luckily I work at a Napa Store. I don't usually use any of the products we sell but I was becoming paranoid over the sap being on my paint so I used some Stoners Tarminator an it took it right off! Phew!!!! :thankyousign:
Try enamel reducer...rub it lightly...it may cause a dull spot,but a quick pass over it with a polishing machine brings it right up...what ever chemical you choose to use ,dont rub it hard!!!
Appreciate the response, I ended up using some Stoners Tarminator an it took it right off! I don't think I would have tried the enamel because I don't have a Polisher at the moment unfortunately.
I've had good luck with No 7 Tar & Bug Remover. CarQuest used to carry it, but no longer. Guess I'll go on-line.
My all time favorite is plain ol' kerosene.
Yes, it will remove ALL of whatever wax/sealant and possibly some surface marring, but the sap will be history.
My $.02
Bill
been trying to remove a dozen or so splotches that I think are dried sap, they are slightly raised above the clear and are light colored and hard as heck, I have tried alcohol, mineral spirits, hand sanitizer, but have been working outside and it is close to winter here and the eliments are working against me. in two days I have arranged to use a local garage and plan on letting some of the above items dwell on the spots to see if given some time in a heated garage might losen them up. Origionally was thinking of using a light polish but was told not to. the thinking was since they were so hard they might be reduced with a DA and the right combination of pad and product, going to leave that as a last resort. still need to try a dedicated tar remover also and goo gone possibly. am I on the right track?
