I got a trinova foam cannon cause they were pretty cheap and I saw a pan the organizer video where he used one and it looked like it worked just as good as the mtm one. So I used it today and the soap comes out very watery even with the top dial adjusted to max suds. My pressure washer is like 2700psi and 2.4gpm so pretty sure it’s not my pressure washer. And I used honey dew snow foam (2oz). When I use the standard 40 deg nozzle on my pressure washer the pressure is very good but it seemed like as soon as I plug in the foam cannnon the pressure drops drastically so idk if that is the issue or if that is even supposed to happen. I am attaching the cannon to the end of the long wand part.... should I remove the wand and get the quick disconnects to be able to attach the cannon closer to the trigger/gun part? Would that help? Not sure why that would matter but...
