AstonSenna
- Apr 21, 2017
- 18
So a tree at home I usually park under has bloomed with lots of flowers. Unfortunately, it rained overnight causing many to fall on my beloved e46. And by the next day they had shriveled up and dried stuck to my paint leaving bad stains. So I washed it and clayed it and tried out my new GG6 with ultimate compound in a few spots where stains were bad, Wolfgang tsr on whole and followed up with ultimate polish and collinite 845. It looked perfect in garage with light on it even although some the stains did take some time and pressure with UC to remove. But today in lowering sunlight , at the right few angles I noticed all the stains on my hood lit up like a Christmas tree. So they're still there , but only in certain lighting. My question is how to remove completely? Because I spent some time on the spots with a LC light cutting pad with UC and then a different light cutting pad with the tsr and those hadn't worked. Will they go away with time ? Or would a hardcore bug remover work even though UC hadn't?
I also only used the Meg's consumer clay found in the clay kit they sell in stores, not the mild or aggressive pro stuff they sell.
Thank you guys!
Mitchell
Thank you guys!
Mitchell
