Do these things oxidize?
pointless one or two rain storms it will be gone.I purchased a 2016 Toyota Tacoma double cab and it came with a bedliner. The bedliner doesn't have a brand name that I can see. It's bolted in, not sprayed on. Do these things oxidize? Should I put some protection on it like 303 Protectant?
My dad has a 2004 Tacoma, and if it has this similar bedliner, the answer is yes it will oxidize. However the problem with using a protectant like 303 among others is it'll leave a slick surface, which isn't good in the truckbed.
This is how the truckbed ended up looking like.
I found the product that worked for me was Meguiars Ultimate Black Trim Restorer [aerosol] It Doesn't leave a slick surface + lasts about a year. Expect to use a whole can to cover the whole truckbed, it's totally worth it. [just make sure to do a test spot 1st, to ensure you're happy with the final look of the product]
This is what it looked like after I used it.
Before:
After:
It would've been even better to have protected it from new. Now you know.![]()
Unbolt it and replace it with line-x. Lifetime warranty, durable, slip resistant and will stand up to anything you throw at it. The plastic liners rub the paint off the metal, then the bed will start rusting from moisture that gets trapped between the liner and the bed.
