flyinion
Member
- May 5, 2011
- 795
So I borrowed my friend's DeWalt 849, not the newer one that's in the AG store but the old one that weighs about 8-10 pounds and goes from 1000rpm up. I was trying to practice on an old door panel he acquired but it didn't go as well as I hoped. The door is not a flat panel, it's an old Honda door and has a bit of a curve to it. Paint is non-metallic red (probably doesn't matter just putting it out there as info). I only have 5.5 x 7/8th inch pads since that's what I use on my current PC 7424 (non-xp about 10+ years old). So I was trying it out with the WG TSR and an old orange LC CCS pad at 1200rpms (AG's recommendation for TSR on the product page).
I was able to control it fairly easy in what would be the horizontal orientation of the door was mounted (i.e. from left to right & right to left laying down) but when it came time to go in what would be a vertical direction if it was mounted (i.e. away and back to me) it was trying to walk all over. It would also try to walk ever time I reversed direction to cover the previous pass by 50%. I called my friend and he said to slightly lift the leading edge of the pad up. That confused me because I've always read to keep it perfectly flat with a rotary but it seemed to help slightly. I still had a lot of problems in the one direction though.
So I guess I could use some more advice on technique. Am I going to fast maybe? Is it the "hard edges" of the CCS pad? I know the flat pads have a rounded edge and the larger 7+ inch rotary specific foam pads have an angled edge. On a positive note, I didn't seem to create any holograms and even though I purposely tried it I couldn't burn the paint or an edge but maybe I didn't have an aggressive enough pad/product/speed to do that.
