I did some internet searching and wasn't satisfied with the information I was seeing, so I thought I'd ask some of the motorheads here at Autogeek for assistance.
A 'parts replacer' would be better fitting name for me than a mechanic. That said, my dad quit tinkering with cars when I was a little boy. Since then everything I've ever learned (not much) about working on cars was learned by rolling up my sleeves and diving in. Let's just say I've learned to know what I can and shouldn't try to do. Here's my dilema...
1996 Mercury Marquis with 122,xxx miles and 4.6l v-8 is running horribly. Car looks stunning and has been garage kept all it's life. However, it recently starting missing while driving down the road, it then began idling a little rough, and has quit a few times when putting it into reverse. I assume it's all related to either bad plugs and/or plug wires. I've never worked on a 4.6l before.
Took it up to autozone, they scanned it and 4, 5, and 7 are misfiring. So, again I'm thinking bad plugs and or wires. I bought both, Duralast wires, Bosch platinum plugs. Not sure if I should upgrade the wires or not. Also, not sure if I need to upgrade to Bosch Double Platinums as some internet searches have suggested. Some of those same sights suggested staying with OEM wires which are Motorcraft...at least I think they are.
Some searches said that the plugs will be gapped correctly from plug manufacturer (1996) for this year 4.6l. What I can't locate (I don't have a manual, but may get one.) is what the factory gap should be...if I even need to change the gap on the new plugs.
That said, does anyone have any other suggestions on tuning this 4.6l up? Fuel filter change, pcv valve, etc.? Car has always ran stellar and was baby'd it's entire life.
Are the plugs down inside the heads on this car like some of other models from 2000 on?
Someone told me some of the plugs were in the back and that I'd need to remove a bunch of stuff along the firewall just to get to them. I've changed plugs on much older v-8's of yesteryear ('89 and further back), but something this new is new to me.
