No, the swirl marks are in the clear coat of the paint, removing the wax won't help and besides, the dish-soap-strips-wax theory is a myth.
If I remember correctly, the TW Hard Shell wax dries fairly quickly, which is why I mentioned using a damp applicator. That will slow down the quick drying a bit. Second, reapply it, using front-to-back straight line motions like I mentioned ... GENTLY and take your time, this is not a race. Don't focus on getting the whole car done, focus on ONE PANEL AT A TIME. Work on the one panel, get it right and move on to the next. If it takes two days to complete the car that way, so be it. It is worth the time.
Even with the dual action polisher, it takes me the better part of an afternoon just to polish out my Camaro and prep it for a sealant and I cut each panel into sections: The hood is 4 sections, each fender and door is 2 sections etc. Even the back bumper is done as 2 sections.
Moral of the story is to take your time and LEARN both the process AND the product you're using. With patience comes perfection.
***EDIT*** Oh, and try to use as little product as possible, less is best. Too much product leads to difficult removal. Difficult removal leads directly to swirl marks & scratching.
Yeah I didnt rush it, used damp MF towel. did not let it sit for 5 minutes like in the instructions, cause it is quite a hard wax. Removing after a minute is already hard. I might try not using swirls, but firstly I need to strip it, and I am not sure how to do it correctly, i can’t put new wax on the old one
+1 for less product more results
P.S. If the holograms are actually in the clear coat I must remove the wax and polish it, I was thinking they are the marks from wax not bonding/not polishing the wax out correctly.
Hard Shell IS difficult to use, it's very Old School. That's why I recommended the Hybrid Solutions Polish and Wax ... much easier to use. I used it on the Camaro on a 90* day in direct sun and it still was easy to use. It also has abrasives and will remove the Hard Shell without having to do a separate polishing step.
What is the picture in the original post (OP) representing? Just the hard shell before removal, right? Was it hard to capture hologram pics?
No special knowledge. Just wanted to ensure I knew the purpose of the photo.Yes you are right, if you have any knowledge to share I will capture it for you. Although I am not sure how that will go, since you have to really get a good angle and a video would do justice better
I feel for you, having wipes that off. Hard Shell was the first stuff I used as a teen. I still have a container of it. I thought I was really on to something when I tried NuFinish. Then soon after I found Meguiar’s, then AG, and the rest has been OCD history.
Strip with a pure polish that will also remove the holograms. Don’t use Turtle Wax polish unless you want TW Polish & Wax. Since you want to test panels and see holograms cone out, I think a pure polish like Meguiar’s Ultimate Polish or Swirl Remover (or anything else in AG Store) would be best.
Holograms should come out fairly easily with a DA and good polish.
What do you mean strip with a pure polish? Compound the wax?? Or is it a product name for stripping wax? Haha. Also I do not have a DA polish. And the “test panel” I did came out great, it is so weird that not all of the car is covered in holograms, only some panels, probably shouldve solo’ed this job, not ask my gf for a helping hand
Don't let her hear you say that :laughing:
I'm pretty sure he's referring to a polish without wax or fillers so you can see the true condition of the paint. He mentioned some good, readily available ones.
You could try a wipe down with a detailer spray first to see if that evens out the finish.
This is what I was thinking. There is a good chance the holograms you are seeing, is just residue left over
