Twin neck measure dispenser bottle like WG Rinseless Wash 1L
PeteT19640
Member
Hi is there any particular bottles I should be ordering?
Want 2x so I can transfer from 1 gallon to a bottle and measure.
Car wash concentrate (exterior) will be going in there.
Thank you
Thank you
Look up bettix bottle
Thank you is the usplastic.com ones OK?
That's where I would get them. As I recall, you are not in the US, I don't know what the shipping charges will be. US Plastics generally has astronomical shipping charges, although recently they seem to have added a USPS option for smaller shipments that is more reasonable. Don't know how that would affect foreign shipments, if they even do that.
You might try Amazon also.
After the 32oz (1 liter), code 66100
i have the 8 oz and 16 oz ones from us plastic. The 8 oz bottles have 1/4 oz and 1/2 oz measurements. The 16 and 32 oz bottles have 1/2 and 1 oz measurements. For me, it depends on the usual amount I'm measuring out as to which one I use. A RW that has a 1 oz to 2 gallon dilution goes in the 8 oz bottles. If it's 1 oz to 1 gallon, it goes in the 16 oz bottle.
Unfortunately they have emailed back to say they don't ship internationally.
Ones on Amazon for some reason won't deliver this particular bottle to New Zealand.
Any other suggestions?
I'm hoping our Aussie members will be able to help you navigate the southern hemisphere supply chains.
It does seem you have some pretty restrictive import regulations.
It would seem the name "bettix" is a brand name, so you search hits will be limited.
Try searching for "twin neck dosing bottle" or "chamber pack bottle" instead.
I got mine from eBay, which the OP would search under "twin chamber bottle", plenty of hits there. You would just check for New Zealand shipping.
Thank you.
The NZ one is made of HDPE plastic is that ok? Would it contaminate the concentrate cleaning like Rinseless Wash and Car wash?
Thank you.
HPDE is desirable here because of the way you squeeze the bottle, it that regard it means the bottle will be resistant to cracking. I've see no reason why it would cause contamination, a quality foam cannon bottles also use HPDE plastic, and many detergents, chemicals and oils come in these bottles, so a car wash soap or rinse-less won't be stressing the material.
Thank you
Could you please send the link to the the one you got and quantity. Some are x10 which is too many.
There are it seems delivery to New Zealand issues for these for some reason.
Thanks again
Thank you
Thanks again
Yeah, I ended up with 10 of the things too. I use them for oil and herbicide for my business, so they will get used up eventually.
