Two "Must Have" Car Washing Tools - The Brass Shut-off Valve & Brass Quick Connector
Without a doubt, the Single Brass Connector Shut-off Valve is one of the best car washing tools ever invented. Period.
Look, we can all discuss which wash mitt we love the best or which car wash soap is our favorite, or talk about hose nozzles, foam guns or pressure washers, but once we get past that, no matter what your personal preference might be we all have to turn the water on and off and that's where the Single Brass Connector Shut Off Valve comes into play.
The Single Brass Connector Shut Off Valve
If I were to count how many steps I've taken over a lifetime to walk back and forth to the water spigot to either turn the water on or turn the water off I could have walked a hundred miles by now easily.
If you don't already have one of these energy and time saving brass shut-off valves on the end of every one of your water hoses around the house or shop, then you're missing boat because once you use a brass water shut-off valve one time you'll never want to be without it again. Yes, that's what I typed, one time.
So take a look at these pictures as they tell the story and then imagine yourself the next time you're using a water hose for ANYTHING and imagine how great it would be if you didn't have to walk all the way back to the water spigot each time you wanted to either turn the water on, or turn the water off.
This is another must-have tool in your detailing arsenal of tools...
[video=youtube_share;Ro9wVJuGcuI] - Two "Must Have" Car Washing Tools - The Brass Shut-off Valve & Brass Quick Connector[/video]
Brass Water Shut-Off Valve in the "On" position
Simply turn the T-handle to turn the water off...
Ready for water again? Simply turn the T-Handle to the open position.
Water's back on! And you didn't have to walk back to the water spigot!
How it works
It's real simple and will give you years of service, there's a swivel ball valve
The Brass Quick Connector
If you've already equipped all your water hoses with a Brass Connector Shut Off Valve, either a single, a double or a 4-way, you're already way ahead of the curve but let me show you another handy tool that's just as cool.
autogeek_2078_73844353
This quick disconnect fitting enables you to switch between water tools on-the-fly!
With a leak-proof seal, you can quickly and easily remove your Fire Hose Nozzle and switch to your Foam Gun in seconds without having to find a pair of pliers to loosen and then tighten the threaded end of your water hose off or onto one of your water tools.
Brass Male Quick Connects 3 Pack
autogeek_2077_46390373
How it works
Simply pull the release back...
Slide the male end of a brass connector into the brass female connector...
Then let go of the release and you're ready for action!
Products Shown
Brass Quick Connector 3-Pack Set
Fire Hose Nozzle
Grit Guard Insert
5 Gallon Wash Bucket System with Dolly - RED
Wolfgang Auto Bathe
:dblthumb2:
I would not be without the shut off valve. A time saver that pays for itself many times over in water savings, and good for the enviroment as well.
Two things I don't have. :)
I do use shut-off valves and quick connectors, but I use plastic ones so there is less chance of dinging my paint in case I should happen to let things get away from me.
That has never happened, but that just means it's waiting to happen some day.
I have a 2-way shut-off fixed close to my wash area with a supply hose, and then two "usable" hoses. I can run the pressure washer and the regular hose without having to connect/disconnect 15 times!
The only problem is that I noticed a major pressure loss. Can't recall off the top of my head what my hose sizes are, but I do know that when you run straight off the spigot the pressure is tremendous.
DLB
DLB
Two things.
1. Obviously the hose size can affect the pressure as can the hose length.
2. What many people don't realize is that shut-off valves and quick connects also can have different internal sizes.
I don't know if it varies by price or not. I just look for the ones with the biggest hole through them when in the open position.
Great review and write-up Mike:xyxthumbs:. I thought I'd add one more thing that I find useful.
If you like to sheet water after rinsing try adding a couple feet of hose after the valve. This takes away the jet spray effect you get when water is forced out of the valve.
With the additional length of hose, now when you take the nozzle off it will gently stream out. Old hoses work good for this. Just buy a quality male/female end and hook it up.
I've never had luck with plastic hose fittings of any type but especially quick connectors. I think these quality brass ones are well worth the extra money.
Craig
That's a great tip. I'v had to run back and forth to shut the water off and turn it back on and it's just not feasible. I was so happy when I finally got the shut off valve a QD adapters.
Welcome to this century, Jake! :laughing: :cheers:
I have the quick disconnect on my water hose. The end that attaches from the hose to the water spigot.
Having worked in the marine industry for decades, I could not be without quality brass quick-disconnects at every point of any hose connections I have.
Imagine using air compressors/tools that had screw-on connections???
Why should our hose connections be any less convenient?
The best part of these old threads is seeing the posts of guys I've forgotten about. A lot of good posters have come and gone. I miss some of them.
The version in the video is a much better quality than the version in the store or what you will find at a home improvement store. The brass T handle is more sturdy than the plastic lever. I usually go through the plastic lever type at least once a year as the lever breaks off. Since I use it in the winter, the plastic will get more brittle.
Just so everyone understands this, don't cheap out and buy the "brass" quick connects found at places like Home Depot. They are NOT solid brass and it doesn't take long for a little phenomena called 'galvanic corrosion' to not just ruin your quick connect, but your hose nozzle as well. Dissimilar metals in the presence of an electrolyte will become an anode and cathode and electrons will travel between the two. Stainless Steel and Solid brass is ok to combine since they're quite similar in their reactivity. Zinc and Aluminum which are very common in hose nozzles and fittings will react with brass and corrode. This is one of the first things i learned when building a custom loop cooling system for my PC... funny that i never thought it would come in handy elsewhere.
