Uber All in one what am i doing wrong
ct18
Member
I cant get it to just wipe off, it seems sticky. I am using G15 with different polishing pads, LC, Car Pro, BS. I have tried small area with 3 to 4 passes larger area with more passes. I let dry for half hour i have also tried letting it dry for a few minutes. I am about to lose my mind and i have 32 oz of this stuff.
Help please.
I prime the pad and then do 3 dots. Should i not prime with uber
"The most common mistake people make when applying an AIO is they don't use enough product. You need to use an ample amount (I think that's one of Mike Phillips' favorite words ).
We all get caught up in the saying "less is more" so most people only apply 2 or 3 "pea sized" drops. While this might make sense for a finishing wax or sealant, it doesn't pertain to an AIO or cleaner wax. An ample amount of product is required so the cleaners in the AIO can effectively remove any embedded dirt and grime.
As with any other product, it can take a car or two before you're able to fully dial in your technique. I think it's safe to say that most every product we carry is easy to use once you get the hang of it.
Tips for using Wolfgang Uber All In One:
1. Ensure an ample amount of product is applied
2. Don't work the product too long - 4-5 passes is all it takes
3. Wipe the product off within 30 seconds of applying it - this is all the time it takes to "dry to a haze." You can eliminate the "drying to a haze" step completely if you can't get the hang of it. This will hardly impact the durability.
Products like Wolfgang Fuzion or BLACKFIRE Wet Diamond All Finish Paint Protection are so easy to remove that they tend to make every other product seem "finicky" or "difficult" by comparison. "
from Nick back in 2014
I used it last weekend on my Chevy Equinox and had difficulty with streaking and smearing. I now know that: I didn't use enough product perhaps, and didn't wipe it off right away.
There's a thread around here on it somewhere.
I've only tried it a few times. I don't think you need use this product as wet as some others. It's very thin and luberous.
With Uber AIO I think you should go a little light on the product, work it until it disappears and wipe away right after.
Or listen to the above post as I don't have that much experience with it, just my thoughts.
Some say way too much product,others said way too little lol the op would have been better off not even posting.
