Don M
Active member
- Jan 8, 2010
- 2,254
- 14
Just saying, before anyone trash talks my having the Camaro undercoated and it still rusting, I had the rustproofing done SEVEN years ago and just this winter, the car developed some surface rust on a lower seam in a rust-prone area. I can live with that.
I found some rust starting on both the wife's Escape (rear hatch bottom seam) and the Camaro (driver's door bottom seam).
The weather is far to cold and crappy to fix the issues now, so I'm researching fixes.
So far, the plan is to clean off the rustproofing (on the Camaro), then wire brush the area, spray OSPHO (phosphoric acid solution) and let it convert the remaining rust and cure for 24 hours. Then take POR-15 and paint over the OSPHO-converted rust. On the Camaro, I won't have to use any touch up paint since the car is already black. On the wife-mobile, there is no undercoating to take care of, so it's just wire brush, treat then POR-15...I already bought a small spray can of touch up paint for match her car (so she doesn't have to look at the repair...even though SHE would never see it...she hasn't seen the rust yet either.
So that's my plan...does any one have any better ideas or products? I'm going hog wild on You Tube looking at rust converters and "Paint over Rust" products. I already have OSPHO from when my wife's Jeep rotted out and we welded some floor panels in, and I can get POR-15 from Summit Racing down the street, but I am open to suggestions and ideas.
