May seem beat to death, but...I've read every post I can on this topic and wanted a few more opinions.
To start with, after my research on this forum, I've concluded that, unless I'm using an AIO, I will use either a paint cleanser ("chemical only") or very mild polish before each sealant application.
Currently I have S100 paint cleanser (supposed to be the same as P21s gloss enhancing paint cleanser) and Meguiars Ultimate Polish. I could of course buy something even a bit finer cut, but I believe M205 is pretty mild.
So the main topic:
I've read opinions by several knowledgable forum posters indicating that basically state: if you're going to go through the trouble of applying something before a sealant to cleanse the paint, why not use a fine or ultra fine cut polish as it will also correct very minor defects. I definitely see their point.
My concern: for maximum protection of the clear coat, wouldn't something essentially non-abrasive such as P21s be ideal? I'm talking about the case where there are either no defects or defects minor enough that you don't really notice. Or perhaps if there are defects that bother you, but not enough to risk thinning the clear coat.
My plan is to wax/seal about every 3 months or so. Maybe I am being too careful with my clear coat?? It's a 2014 mustang if that helps, as I'm not sure if this is soft/medium/hard paint. Anybody know if I could polish 4x/year for 10 years with a fine or ultra fine cut polish without ill effects on the clear coat? I currently only apply by hand with meguiars hand polishing foam pads.
Thoughts?
Thanks everyone!:xyxthumbs:
So the main topic:
Thoughts?
