SeaJay's
- Aug 2, 2010
- 3,070
I'm in the process of doing a full paint correction on a 66 Vette Stingray. It's black of course! So, the correction process is going very slowly as I expected. The paint is extremely hard to correct which I already know about Vettes. However, the clear on this car is the softest I've ever come across. The car had a full frame off restoration done 3 years ago. The owner then brought it to a local shop to have some motor work done, and the guy at this shop decided to wash and attempt to buff it out. Let's just say that this car is COVERED in holograms. Here is a pic of the hood...sorry for the crappy pic I took it on my iPhone.
Anyway, after messing around with different producst, pads, etc to find the right combo I finally settled on my Flex using the orange compressor pads and WG Total swirl remover, followed up by Menz PO85rd on a greed LC CCS pad on my PC. I initially went with the white pad but was getting tick marks.
Anyway, now I'm having the issue that when I remove the PO85rd, I'm putting slight scratches back into the paint when I wipe. I'm using the Sasquatch MF's from CG which are the softest MF's I have. Even being very gentle and not putting any pressure down they are still leaving slight marks. It's driving me absolutely insane.
I've tried using some ONR diluted to quick detailer to assist in removing the product, but even that isn't working.
Any tips or suggestions on how I can keep this from happening. I'm scared I'm going to do all this work and then when I do my final wash to remove all the polishing oils that I'm going to end up with a surface that isn't flawless.
As always I appreciate all the help!
