S Sebs New member Joined Dec 26, 2012 Messages 2 Reaction score 0 Dec 27, 2012 #1 Hi all, I have a Karcher HD 6/15 pressure water system and I recently bought a PA foam lance along with the HD/HDS adapter. I cannot figure out how to connect them both together... Hope there is someone that has done this before.... Pics below. Thanks.
M Mike PhillipsMike Phillips is verified member. Active member Joined Dec 5, 2022 Messages 51,004 Reaction score 6 Dec 27, 2012 #2 You need to remove the long steel tube from the handle of your pressure washer wand. Then replace the steel tube with the Foam Gun. If that makes sense?
S Sebs New member Joined Dec 26, 2012 Messages 2 Reaction score 0 Dec 27, 2012 Thread starter #3 Thanks Mike. I'm not sure if that comes off as the whole gun is sealed by screws. I can take off the end nozzle (pic 3) by unscrewing it but the male connector doesn't fit the foam gun adapter.
