T0RCH3D
- May 8, 2012
- 218
How's it goin guys! This may not be the section or forum for this question but I figured you all here have a very broad skill set and know a thing or two about automotive painting and more importantly clear coat application.
After removing the hood liner so the supercharger can breathe and reduce heat soak I was left with the underside of the hood looking like this. Ford did not paint the entire underside of the hood since their was the line covering it. So after looking at the underside of my hood with disgust every time I was working on the car and seeing how much of an eye sore it was I began to do some research and gathered the supplies in order to paint the hood myself. I came across a member on another forum who preformed this task with ease and incredible results. Anyways, it was not the most ideal setup and you can only expect so much from a "rattle can" job but I figured I would give it a shot and if I failed I would have it professionally done. All in all it went well, the prep and paint procedure came out flawless, but the clear application on the other hand was not so smooth. I don't want to chalk it up as a failed attempt until I have exhausted all other chances of fixing what I have done. Below is the products I used and the process with pictures:
Products:
12oz Aresol of "Torch Red" paint code Ford D3 (2 Cans)
12oz Aresol of High Gloss Clear Coat
8oz Aresol Duplicolor Gloss Clear (3 Cans)
2oz Spray Bottle of Prep Solvent Wax and Grease Remover
1 3M Tack Cloth
Goal:
Process
First I removed the hood and brought it into a heated trailer around 60+ degrees I would say (outdoor temperature: 48 degrees). I sanded the stickers and other blemishes/defects that existed on the hood. Then masked the areas and used prep solvent and a tack cloth prepping for base coat number one.
After I proceeded to apply thin coats of on the hood. 5 coats total.
Now was time for clear. I wait 45 minutes after the last coat of paint and applied a medium of coat of clear. Then 2 more 15 minutes apart totaling in 3 coats and 1 full 12 oz can. The finish was almost similar to the look after final coat of paint. Very little added gloss. So I went to advanced and bought 3 8oz cans duplicolor clear coat. This added some gloss to the finish but not close to OEM finish.
Here is after 4 cans of clear. An improvement but minimal gloss:
Verdict?:
What can be done to achieve the gloss finish I am looking for. I did not put the hood back on the car due to myself not being satisfied and not finding an answer to the solution. I was told to wet sand at the finest grit paper with soapy water, but I do not see the benefit in this? Do I need to apply more clear, which is hard to believe? Do I need to apply clear in a different location/temperature? Was the duplicolor clear I used not a good product? Is it maybe the lighting? Any advice is appreciated!
Products:
1 3M Tack Cloth
Goal:
Process
Verdict?:
