My suggestion to Flex is to make slightly more powerful 3401, with a bit more pad rotation at slower speeds.
The front of the new 3401 polisher should be like the PE-14, a kind of 'grab to the head of the polisher' instead of a handle.
Regarding the larger throw, 12mm would be good (in my imagination, I'm not engineer).
Lastly, I suggest to Lake Country to create an Hybrid pad line for the Flex, where the velcro size would fit PERFECTLY the 4 3/8 backing plate, giving the foam side ~5.5" in size, it'll be the best for Hybrid pads, trust me.
Otherwise, I suggest to Flex create a 4" standard original backing plate, and why not, a 3" plate as well for the new polisher.
In advance, if there will be a new Flex with improvements, I'll get one as soon as they release.
Kind Regards.
Maybe it's just me but I would rather see the speed switch on top of the handle on the 3401 instead of on the side. My thumb always want to reach there too adjust the speed.
Could you post a link to Flex releasing a new polisher at SEMA. I can't find any info. I was getting ready to order an extra for back up but will wait if a new design is in the works . Thanks
