UPDATE - Aluminum Clad Wheel Polishing
caudleej
After researching and reading comments posted by members here I used what I learned to go at the wheels today. I went simple and used some of my consumer line Meguiar's products I had in the stash. I am very happy with the results.
Through research and information from others on here about clear coated aluminum wheels I figured out that OEM wheels are probably not polished to perfection prior to being clear coated and the clear coat tends to be a bit on the hazy size due to the reflectivity of the aluminum. Additionally a lot of the scratches you see are from rocks, sand, etc. that are almost through the clear coat so therefore they will not be removed by polishing.
Anyhow, I used my Mother's PowerCone, Meguiar's CCS Polish, and Meguiar's Cleaner Wax Paste, and a clay bar.
I clayed the wheels which made a huge improvement in the appearance alone followed by working the polish with the PowerCone and application of the cleaner wax.
I will most likely follow up in a day or so with a more durable wax or sealant. I mainly used the cleaner wax for its cleansers and cleaners incorporated.
The wheels have a nice glow to them and look well taken care of. I have learned that you cannot expect perfection from these OEM wheels because they where not perfect to begin with.
View attachment 40561View attachment 40562
That looks great! Did you remove your wheels to Polish? Any thing else you might have discovered that yo u like?
