justin_murphy
- May 7, 2006
- 2,852
You all pretty much know my Optimum Polish/Poli-Seal mix. I was a little worried about it's durability. I'm not now! These are some pics of the Mustang detailed about 3 weeks ago.
Waxmax said:Justin- you are the expert, but to my eye, the beads in some areas seem fairly large, particularly on the trunk area. I typically like to see tight, dime size or smaller beads (even after 3 weeks). Maybe it's just my old eyes when viewing your pics. JMO.
Al-53 said:By diluting the the product ..do you think it will lessen the ratio of sealant applied to the car....plus it having caranuba in it..it should bead more so sheet unless the wax longevity is short..To me diluting a product like that you loose on one end and gain on another....you would gain on the polish effects but loose in the sealant as it would dilute to some effect by 25%
AL
Stuff said:Do you have any more information about this comb? How do you go about mixing/making it? The polish does not counteract/take off the sealant as you put it on? Hard question but how long do you expect the protection to last? How good of a job does it do taking care of defects? How do you use it on the vehicle. Wow I'm full of questions I just think this is an interesting concept. Thanks a lot.
Gottabekin said:Great to know optimum works well. Hey Justin, when you apply the 75/25 mix, you will be using a cutting pad and don't have to use a polish pad to finish up?
