Upgp & ocw
Larry S
I purchased some UPGP on BOGO and wanted to apply this year in the spring after my surface prep. I also have a gallon of OCW, which I have been using regularly.
I know sealants are not supposed to go over wax. I was wondering if anyone has had any experience with using them both. Applying OCW after the UPGP as a booster and then re applying the UPGP, and so on.
Thanks,
Larry
The UPGP after 2 coats is shinier and slicker than 2 coats of OCW. You definitely can use OCW to boost the durabilty of UPGP.
OCW is a fantastic spray wax with relatively good durability. I find that OCW changes the look of metallic paints more so than UPGP. You may or may not like the muting effect.
UPGP should always be underneath OCW.
+1
I like 3 coats of UPGP. The shine and gloss really came alive after 3. Plus it is so easy to use and apply.
Thanks, What about a spray sealant like Wolfgang? Could I put more coats of UPGP in between that?
+1
I think I will use 3 coats, I mean it's so easy anyway.
