Upgp
bodavenport
How long do you guys let UPGP cure before you hit it with some detail spray? The bottle really doesn't say much about it. I have been letting it cure for 30-45 minutes depending on how hot it is. Is that sufficient for max results?
I'd wait 24 hours. Not sure why you would want to use a detail spray on it after 45 min anyway.
detail spray?
hot it is.
•Whether it's after the first 45 minutes;
or, even after the recommended 12 hrs.
(so the "full" cure-time can be reached):
1.) Unless there are any noticeable
"streak(s)"; then:
2.) There should be no need to hit the
UPGP with a Detail Spray to remove
said "streak(s)".
•How goes that ol' saying?
WOWA products are the best
When they are touched less.
Yes I am still working on getting the right amount to dry streak free, still using too much I suppose
No harm in leveling with a dry microfiber after completing a panel. Just a light swipe, as the product will have already flashed, aside from any High spots.
Thanks for the link so the next question is if I did use too much and have a little streaking and do not have 12 hours to allow further curing, if I can apply a second coat in 45 minutes than a small spritz with a detail spray should not remove the product, right?
See if just a soft MF without a detail spray will take the streaking off first tho. U want to try to avoid water based products as that may alter the curing of product. The 45 min window is for a second coat as the product bonds to itself.
