First time using these Lake County Hydro-tech pads yesterday and ran into some issues. I'm going to post up some pics below that show the problems that I was having. Keep in mind that these were brands new pads never used before and I only got through three panels before I started experiencing these issues.
In these pics, you can see where the edges of the pads started to deteriorate.
Hard to see in this pic, but the middle of the pad started to concave in a little bit.
Had to finish the job with my uber foam pads which as you can see gave me no trouble at all.
Here's some insight into how I was using these when this happened.
Griots Garage 6", speeds 4-5, 4-6 section passes with a 24"x24" working area. Primed the pad initially with 4 drops of Menzerna FG400 and then followed up with 3 pea-dime size drops for each new working area. Applied 9-15lbs of pressure consistently for every pass.
Since these pads are new to me (although I have used closed cell pads before), I can only attribute this to being defected pads. Any insight?
