Ok, so no steel wool then
I am unsure what those kitchen scrubbers made of rubber are... can you post a picture?
If I can find something that is fast to do, and that I can do during the wash without having to pull out the polisher and spend 20 minutes on the windshield I am all for it. I could use that in low cost détails.
What about magic eracers (mr. Clean stuff) on the windshield? Would that do a decent job?
I have yet to find a razor blade+handle. Where do you guys get this? Closest I found was at the dollar store, the razor blade is attached and the handle is much shorter. Also the blade is twice as wide so I don't think it would conform to the curvature of the windshield as well.
I am also wondering if Nano Skin Medium Grade (red) sponges would do a decent job for this.
So many questionsSorry guys
Hey guys,
I just watched a video explaining how to polish the windshield using 0000 steel wool.
Do any of you guys use this technique and if so how does it compare to using a DA with a glass polishing pad and glass polish?
Nanoskin autoscrubber, I use the 4 inch for the cyclo. It gets into the corners better than the 6 inch. Use their hydrophobic lube, and you'll be set.
What are you trying to accomplish? Defect removal (scratches) or just decontaminating the glass? If the later, I would just use clay or a clay substitute with ONR. Another thing you could use is a non or slightly abrasive polish (like PB's Pro Polish) on a Polishin' Pal with a white LC 3.5" beveled pad. That would make short work of it. Even AIO, like Mother's Liquid AIO Cleaner Wax can work wonders on glass by hand.
If your going after defects, you going to need big *ss Popeye muscle man arms to get out scratches without a machine (ask me how I know).
It won't polish the glass and is nothing like using a polishing pad. Back when I did very bad cars on a daily basis, I would quickly go over the windshield with "0000" steel wool to remove the worst contaminants before claying.
If used with something like ONR it won't leave any scratches and does an excellent job of removing contaminants.
You can also quickly go over the windows with a razor blade (lots of lube and at a 45 degree or less angle) to quickly remove contaminants before claying the windows. This is actually used even in very high end detailing.
These methods are normally used during the wash or prep process before detailing.
Here's another one with the man himself, Dennis Gage...
Autogeek on My Classic Car - Episode #18 Glass Polishing
Episode #18 Glass Polishing on My Classic Car
This episode features James Otto and some of the cars in his car collection and in the Autogeek segment we feature,
Pinnacle Glassworks Water Spot Remover
Pinnacle GlassCoat Window Sealant with Rain Repellent
Porter Cable 7424XP
4" Spot Repair Pads
All kinds of ways to get glass clean...
I was just curious if there was a quicker way to do it so it could be included in an entry level detail package. Doing the glass polishing on the entire car will take about an hour, maybe a bit less.. So that's a no-no for a 60$ detail.
But if I can take a nanoskin sponge and rub the glass for 2 minutes per pannel, then it's doable.
You always make things look easy to us Mike:dblthumb2:
Can't tell you how much I've learned from your post and vids.
Thanks
