How do you use a dual-action polisher on a car that has a lot of curves and contours? The instructions and videos say to have the pad flat on the surface, but if that's the case there's going to be a few areas that I won't be about to polish by machine. The 2010 Camaro's have a few curves on the panels. For example, on the RS model, if you look at the hood the middle portion of it is raised. The sides of the hood sort of curve up to the higher middle portion. Can you safely use a polisher on that curved portion? Also, the rear fender (close to the doors) have ridges in them, how would one use a DA on that area? Thanks in advance for your answers!
