I tried using some of the Meguiars Ultimate Compound by hand on a junk test pannel that I try new products on before actually touching a vehicle. To get my pannel all light scratched and swirled up I ran a swish broom over it. I thoroughly washed the pannel before using the product, so there was no chance of any dirt left behind. Anyways, the UC did a great job at removing the scratches and swirls by hand. But after wiping the product off, I can still see some light hazing and scratches under the Brinkman that are going the same direction as I was working the product. I used some Griots Pre Wax Cleanser on the area, just incase it was streaking from the product, but the hazing still remained. There's no sun now to do a true test, but if it's visible under the Brinkman I am sure day time results will show it even more.
I used the yellow Pinnacle foam applicators, http://www.autogeek.net/pinfoamwaxap1.html, and primed the applicator by putting some product on the pad and spreading it across it where it was covering the pores of the foam but not clogging them. Then I started working in the product, a little lightly the first pass or so to spread it, then increasing it and then putting some passion behind the pad. I did this for 5 or 6 passes or so. For the last couple of passes I lightened up on the pressure. All of this was done going one direction using overlapping passes in around an 8" x 5" area on an older Saturn SC2 coupe red door pannel
I folowed the Mike Phillips guide as mentioned other than putting the product on the surface. How is it that many people can get LSP results with this the UC, even on darker vehicles? What am I doing wrong here? Am I expecting too much from Ultimate Compound alone being LSP ready by hand? If I can't get this little area by hand looking good, I am a little nervous now about using this with the 7424. Any tips to get this finish LSP ready looking with UC alone by hand?
