Using soap pressure washer nozzle for foam?
dbinott
I have an electric PW and it came with the soap nozzle. Will this produce similar results to using a foam cannon?
no, it's a sun joe spx3000. it's just the black nozzle, not a whole cannister.
It sounds like the typical "soap nozzle". It is a wide fan spray with large orifice that drops the pressure way down so the soap injector will deliver soap. The result is more like a foam gun than a foam cannon.
It needs to be a soap designed for pressure washers also. My water hose plus foam gun puts out way more Suds than the soap nozzle on my pressure washer
