Using The Orbital After Wet Sanding
BillH
I am getting down to the final part of restoring the finish on my 65 Shelby. I have wet sanded the car, 2K, 2500K and 3K (car originally done with Lacquer 30 years ago, never wet sanded) and started with a rotary and a wool pad using 105. I go over the panel twice. Next, I use the orbital with 205, also two times.
My issue is the tops of the fenders and the glass hood. Does it make sense to use the orbital instead of the rotary? These areas, in the case of the fenders, are not very wide. The stripes get masked and any work done here is done by hand.
Thanks
I would think that small pads on the rotary would be more precise in the tight areas. Maybe the first pass rotary and second with the DA?
I have used the DA with surbuf pads right after 2000 grit, worked almost as fast as the rotary on wool. It shouldn't take more than a couple of passes even with an orange pad to get through the sanding marks with the DA.
I found shaft extensions for the rotary to be the one of the best tools for gaining more precise control in tight areas.
It's really great to follow you through your progress on your 1965 Shelby Mustang, when you get ready to share pictures, let me know if I can be of help getting the sized correctly and uploaded into your gallery.
Thanks
I've a few tidbits of info below, hopefully some of it will help...
We have the The Edge 2000 6 Inch Wool Buffing Pads that would work for most thin, long panels on a 1965 Mustang. There's also 3", 3.5" and 4" foam pads and some of these are cutting pads.
There's also the Meguiar's Burgundy Soft Buff 4" foam Cutting Pads
If it has paint... it gets polished...
This is the new Meguiar's Burgundy Soft Buff 4" foam Cutting Pad on a 2 3/4" backing plate attached to the Flex 3403
Using M105 for my cutting compound, it can sometimes be difficult to wipe off for a variety of reasons but if you wipe whatever panel you're working on immediately then it wipes off pretty easy, that is to wipe the film residue off before it fully dries.
Can't endorse the Flex 3403 Lightweight Rotary Buffer enough, this is to date, one of the nicest rotary buffers I've ever used and work great for small pads in tight areas or thin panels. For the major panels I'm using the Makita 9227C but for "edging" this car and any and all small, thin panels or tight areas I'm using the 3403
Here's a little tip, anytime you're buffing next to an adjacent panel and it's possible you could run the vertical or side edge of your pad into the paint, lubricate it by working some of the product you're using on the face of the pad onto and into the foam. This will help to keep from generating too much heat and burning the paint and also in the case of these lower panels, help me to remove some of the sanding marks on the angled section.
It's this little long thin section I'm trying to improve and protect.
Picking up just a portion of the bead of product using the 10 @ 10 technique and then working it over a portion of this panel.
Note the safety glasses... don't want any splatter in my eyes...
After removing the sanding marks in the front portion of that panel I picked up my bead and tackled the rear portion...
My personal preference is not handle, if there is a handle I actually like a Stick Handle as I can quickly and easily either remove it or move it from side to side depending upon how it works best for the panel.
Much better...
And these two "fiber" 3" and 3.5" pads from this thread,
http://www.autogeekonline.net/forum...uiars-easy-buff-knitted-wool-3-inch-pads.html
Here's a brand new one next to one I used with M105 on the Flex 3403 Lightweight Rotary Buffer to remove sanding marks.
The way the fibers have matted down in a twisted fashion is NORMAL
Here's a brand new Meguiars Easy Buff Knitted Wool 3 Inch Pad next to a Foamed Wool 3.5 inch Buffing & Polishing Pad
Here they are upside down with a 2 3/4" rotary buffer backing plate attacked to give you an idea of general size.
These are both good for aggressive cutting on thin panes or for spot repair when using a rotary buffer.
I have used the DA with SurBuf pads right after 2000 grit, worked almost as fast as the rotary on wool. It shouldn't take more than a couple of passes even with an orange pad to get through the sanding marks with the DA.
Good call, plus we carry 4" Surbuf pads or if you go with the 5.5" Surbuf pads you can also use a 5.5 interface pad to provide some extra cushion if you wanted... this would decrease cutting action a little but some people like the feel of a little extra cushion for "important" careful work.
Surbuf with M105 will remove the sanding marks, just not as fast as a wool pad on a rotary but with good technique it will do it fast enough plus no rotary buffer swirls to remove just micro-marring. You would remove most of the risk of burning paint due to the free rotating spindle assembly.
I aggree... like this only for car panel applications... the below works well for cleaning pads in pad washers too...
Optimum Double-Sided Rotary Adapter - 3M Quick Release Adapter
I started with the Edge 6" Medium Cut Wool Buffing pad, the unique center system reduces/removes vibration while buffing.
Note I have removed the handle options from the Flex 3403 Lightweight Rotary Buffer, this gets them out of the way for intricate work in tight spaces and is my own personal preference.
Some links for some of the above items...
Thanks for all of the help, of course, none of these items are available locally, so it looks like I am going to have to place another order. I think I will try the foam pads on the orbital after finish sanding with 3000. Let you know how it turns out.
Thanks again
Bill
