I read several places and by well respected individuals here that WD40 makes a great low cost tar remover. I cleaned up the wifes white suv today and decided to try it out. Im not sure my application method is the best though. I washed the car, sprayed WD40 directly to the contaminated areas. Agitated/removed tar with bug/ tar sponge, rinsed area, and rewashed treated areas. Is there are better method? Will this method damage/ remove lsp's? iIf so will i have to do a ipa wipe down before applying lsp after wash?
It will remove tar but it is a quick and nasty solution for sorting out a bit of tar, here and there. If you have any amount of tar, it is neither the most effective, safest or cheapest option. Unfortunately there are many people on the internet who seem entirely oblivious to this.
The first thing to remember is that WD40 is not water soluble - once it is on your paint, it ain't coming off without a fight. Worse than this, WD40 is specifically designed to resist water and we don't actually know what is in there doing it. If you do use it, you better really work on the paint to ensure it is clean after, especially if you are going to use a coating.
A dedicated tar remover (solvent base) will be designed such that it does not have elements which are specifically hard to remove and it will have elements which make it easy to rinse (it will go white when you rinse it, as those added bits do their work to help you rinse the oily solvent away). If you must do it on the cheap, use something like mineral spirits. Again, this does not rinse easily with water, so you need to do a really good clean and wipe after, or you could have oil left on the surface. However, compared to WD40, it should eventually all evaporate away, making it a much better option.
Methodology - tar removers are typically old fashioned. They are routinely expensive because they are 100% active products (note, the water based products on the market are rubbish and not worth the money as 'tar' removers). On the wider market, it is hard to make profit because of the high basic price and that means that few people are willing to pay the money for a technologically superior solution. Basically, almost all of them are watery consistency and dry out fast. As such, you just have to keep spraying and wiping until the tar is gone. There are better ways of doing it (we certainly have a massively superior product) but almost impossible to find this sort of thing on your side of the water.
