Hi There,
So far I have only worked with LC Constant pressure pads, most of which are open cell structure and some hex pads that are either open or closed based on the colour. Never had a problem using them with any compounds or polishes till I started using polishes from Scholl Concepts and Menzerna.
I picked up the Scholl Concepts S40 finishing polish which is their finest/least aggressive jeweling polish and their Black softtouch Waffle finishing pad, which is their softest finishing pad. However, I now read on their website that S40 is a micro polish (no clue what that means) and should not be used with their black finishing pad as it is open cell and the polish will clog up the pad. I have never heard of anything like this and it confused the day lights out of me.
Now I am thinking if I can use any finishing polish with that pad. I have some Menzerna SF4500. How do I know if that is also a micro polish or not? Is there any rule that you should always use a closed cell pad with a finishing polish, irrespective of the fact whether it is a SMAT or DAT Polish?
I want to get into the thick of all things Scholl and try all of the compounds and polishes but I am now uncertain if their pads are the best choice or I should invest in LC Hydro tech pads instead. The HT pads are designed for use with a rotary and I like that. I also like that all of them are close cell so good to work with any brand of polish including Scholl. Have I got it right or should I buy into the Scholl claim that their polishes and pads are part of a system and they work better together?
Thank you for reading.
