Jimmy Vegas
- Mar 9, 2016
- 293
Hi Mike,
I've been working on cleaning and polishing the paint on my '72 Chevelle which sat for many years in my father's garage, and was only washed a few times when I was home visiting in warmer weather.
There would be a layer of dust sitting for extended periods that seemed to have embedded into the paint on the horizontal surfaces. (The convertible top will be replaced as it is beyond cleaning.) So far I've worked on the deck lid by first waterless washing with Wolfgang Uber, then clayed with Mothers Clay kit, a second pass with BlackFire Poly clay using Uber mixed as lube. As the clay was still coming back dirty, I then fine Nanoskin on my PC7424XP with Glide. Next, HD Polish+ on a Buff & Shine orange pads, then a white pad with BlackFire Total Polish and Seal. It looks great, but judging from the way the pads looked afterwards, I'm willing to bet there are still more contaminants in the paint. I'll be going over the trunk again after I finish the first pass on the rest of the car. I didn't use an iron remover, as there is NO WAY I'm spraying Iron X in a closed garage. (it's getting cold here in PA.)
I didn't take a picture of the white pads, but they were light gray. Which seemed to be the color of the BF Polish.
I've purchased the Meguiars MF DA Kit and used the pads with the included products on the driver side quarter with great results, and am comfortable finishing the car with it. (At least the vertical surfaces.)
My question is this, considering how dirty the deck lid was, what should I do with the hood? I intend to use the same wash, Mother's Clay, Medium Nanoskin (most likely by hand as I have the 4 inch pads). What would you recommend as the next step in that process? Should I use an additional cleaner/polishes before attempting to correct the swirls? There is a decent amount (a lot) of swirling in the paint, but I want to make sure I'm getting all of the contaminants out prior to attempting to polish.
Also, any advice you may have for the vertical surfaces will be greatly appreciated.
Many thanks,
Jim
P.S. I forgot to mention, the car was repainted by a body shop in 1985. I believe it is a lacquer with clear coat.
B&S Orange pad using 3DHD Polish+
Many thanks,
Jim
