Video- Edge Buffing Pads
Meghan
Super Moderator
The Edge 2000 Buffing Pads with the Quick Connect Adapter will change the way you polish your car!
There is no need for backing plates anymore, thanks to a radical, technological breakthrough in buffing pad design, fittingly called The Edge™. Changing buffing pads takes seconds, through a unique, non-Velcro system. These reticulated polyester urethane foam pads are double-sided, and feature a quick connect/disconnect method of interchanging. This system adds a level of comfort to the buffing process, as each pads fits like a glove on the machine polisher, and changing a pad is much easier through use of the Quick Change Adapter.
Edge Premium Buffing System Foam Pads
[ame=http://www.youtube.com/watch?v=cd0CAm6GQW0]YouTube - Edge 2000 Buffing Pads[/video]​
