Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Video: How to polish paint using the GYEON Polishes and Compounds
Jeff McEachran stopped by and together with Yancy we shot a new video showcasing the GYEON compound, polish and primer.
GYEON Q2M Compound
High cutting abilities with low dusting!
GYEON Q2M Compound is a heavy cutting product that delivers extreme correcting ability with low level dusting and an incomparable finish. Designed to remove medium to heavy swirls, scratches, and other paint imperfections, GYEON Q2M Compound fully corrects your paint and preps it for a follow-up polish for unparalleled results. To get that perfect paint before coating, correct it with GYEON Q2M Compound!
Gyeon Compound
GYEON Q2M Compound 120 ml.
GYEON Q2M Polish
For that perfect, hologram free finish and intense deep gloss!
GYEON Q2M Polish is a low-dusting, high-quality polish that will finish off your paint correction detail with superior results. Most commonly used as a follow up product to GYEON Q2M Compound, this fast acting polish can be used with a Rotary or Dual Action polisher and in most cases eliminates the need to use a finishing product, thanks to the high-quality finish left behind. Also perfect for use as a one-step product, GYEON Q2M Polish is a super versatile addition to your detailing kit.
Gyeon Polish
GYEON Q2M Polish
GYEON Q2 Primer
Primed for a perfect finish
GYEON Q2 Primer combines two product uses to form this easy-to-use paint finisher and primer. Providing superb pre-coating surface preparation and an incredibly gloss finish, GYEON Q2 Primer will perfect the finish on even the hardest paints and leave a smooth and slick surface, ready to be coated. Get your car’s surface PRIMED for perfection with GYEON Q2 Primer.
Gyeon Primer --> GYEON Q2 Primer 120 ml.
GYEON Q2M Compound
Gyeon Compound
GYEON Q2M Polish
Gyeon Polish
GYEON Q2M Polish
GYEON Q2 Primer
