Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Video: How to use the Nomad 18 Volt Portable Power Cleaner
Take the car wash with you!
The Nomad 18 Volt Portable Power Cleaner brings the car wash to your vehicle, no matter where you are! With this portable power washer, you can wash and rinse your vehicle in a matter of minutes without a water hose. The Nomad 18 Volt Portable Power Cleaner packs its own water so washing your car is fast, easy, and convenient.
The Nomad 18 Volt Portable Power Cleaner makes it simple to have a spotless vehicle all the time. No car wash nearby? No water hose? No problem! The Nomad 18 Volt Portable Power Cleaner has a 3.5 gallon tank and a long-lasting 18 volt battery to deliver dirt-busting power to your vehicle. The Nomad's adjustable sprayer is capable of blasting mud out of wheel wells and off rocker panels, yet it's gentle enough to wash chrome, molding, and under the hood.
The Nomad 18 Volt Portable Power Cleaner provides car care enthusiasts like you with the ultimate freedom to clean your vehicle anywhere. There's no cord so there are no restrictions. Work around your vehicle easily and within minutes. The swiveling hose quick connect keeps the hose from kinking and twisting. The padded shoulder strap and over-molded handle allow you to move the Nomad 18 Volt Portable Power Cleaner easily around your vehicle.
The best part about the Nomad 18 Volt Portable Power Cleaner is its portability! Take it anywhere. It's completely self-contained. There are limitless uses for a portable power cleaner.
The Nomad is built for an active lifestyle! The 3.5 gallon water tank has thick-walled construction. The water tank unlatches from the base and can be filled in any water source. A built-in filter keeps leaves and debris from entering the tank.
Auto enthusiasts, use distilled water in the Nomad 18 Volt Portable Power Cleaner for a spot-free rinse! Distilled water has no minerals so you can wash and rinse your vehicle without water spots.
The Nomad 18 Volt Portable cordless power washer is better than a traditional power washer. The Nomad is smaller and easier to transport. The Nomad is nearly silent. You won't disturb others when you use it. The Nomad is cordless so there's no need for a plug. It runs on a rechargeable 18 volt battery and includes an optional 12 volt power cord. But, just like a pressure washer, the Nomad 18 Volt Portable Power Cleaner has an adjustable trigger sprayer and enough power to give your vehicle a thorough cleaning.
The Nomad 18 Volt Portable Power Cleaner has a built-in water filter and includes a 12 volt port, padded shoulder strap, and 18 volt battery and charger. The Nomad has a one year warranty.
So what are you waiting for? Whether your vehicle is a pristine show car or it puts the sport in sport utility vehicle, the Nomad 18 Volt Portable Power Cleaner gives you the power to clean it up anywhere.
On Autogeek.net
[ame=http://www.youtube.com/watch?v=RSFivrYzyog]How to use the Nomad 18 Volt Portable Power Cleaner - YouTube[/video]Take the car wash with you!
- Clean your vehicle on site at a car show or rally.
- Wash your vehicle even if you live in an apartment or condo with no water hose access.
- Rinse away bird droppings and bug remains quickly while you're on road trips.
- Rinse down your vehicle and your fishing gear after a day on the beach to remove sand and salt water.
- Rinse mud off wheel wells and rocker panels after off-roading.
- Clean up after tailgating.
- Rinse off sporting equipment and camping gear.
- Clean up tools.
- Take the Nomad along on camping and hunting trips as a source of fresh water for showers or cleaning game.
- Clean your RV wherever you are.
- Rinse salt water off your boat.
- And much more!
On Autogeek.net
