Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Video: Remove Tar and Bugs with Stoner Tarminator Bug and Tar Remover
Remove Tar and Bugs with Stoner Tarminator Bug and Tar Remover[ame=http://www.youtube.com/watch?v=uSdQ_l_M5Z4]Remove Tar and Bugs with Stoner Tarminator Bug and Tar Remover - YouTube[/video]
Get that turnpike tar off your car!
No need to scrub, don’t get out the abrasive tools, forget the soap.. You need Tarminator, the only solution that works. And it’s always friendly to your car's finish. This is the product that enthusiasts and collectors rave about! So don’t scrub it off, spray it away!
Specifically designed to remove road tar, grease, asphalt, sap, and all other manner of nasty sticky stuff off your car. Tarminator is the unique formula professional detailers reach for when faced with the daunting task of removing substances that, otherwise would be cemented on. It saves tons of time.. simply spray it on and wipe it off. And it won’t damage paints or clear coats!
Tarminator uses a unique ‘Micro Active’ cleaning technology that actually breaks down the molecules in sap, grease, tar and other sticky compounds.
You never need to scrub when using Tarminator. Unlike other products, the advanced technology used in Tarminator really works! You’ll be amazed at how previously impossible grime seems to glide off like butter on a hot knife! Why spend precious time picking away at the same baked-on sludge you tried to get off last week?
Leave it there and eventually it will damage your car's finish. You need Tarminator!
Tarminator is safe to use on paints and is thoroughly product tested. It is a powerful cleaner, though, so use care around plastics, adhesives and decals. Remember that it is formulated to get the stuck – unstuck! We always recommend you spray Tarminator directly into a clean, dry cloth and gently wipe it over your pre-washed surface. Pre-washing your vehicle prevents rubbing excess grit and grime into the paint during application, so it’s a good idea to give your car a wash prior to applying Tarminator.
Use the solution the Pros use, just once.. and you’ll never reach for anything else. It’s safe, It’s fast, and it works!
Five amazing cleaners in one spray can! Stoner® Tarminator quickly dissolves and removes:
Simply spray and wipe to safely clean painted clearcoat surfaces and all exterior auto trim.
10 oz. - Aerosol
On Autogeek.net
- tar
- tree sap
- grease
- bugs & road grime
- wax build-up
10 oz. - Aerosol
On Autogeek.net
