Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Video: RUPES BigFoot LHR15 & LHR21Random Orbital Polishers
On Autogeek.com
Rupes BigFoot LHR15 Mark II Random Orbital Polisher - FREE SHIPPING!
The next evolution of the revolutionary Rupes BigFoot polishers!
The next generation of Rupes is here – The Rupes Bigfoot LHR21 and LHR15 Mark II Polishers. Built with everything that made the original Rupes LHR 21 & 15 one of the best, the new Rupes Mark II series are going to blow you away. Correct your paint faster and more efficiently than ever before. With improvements made to both the body, chassis, and motor, the Rupes LHR15 Mark II and LHR21 Mark II provides 30% more efficiency than the original machines, making correcting your paint smoother than ever before.
The Rupes BigFoot LHR15 Mark II has the same, extra-large 15 millimeter throw as the original LHR15, making correcting paint something you’ll want to do for hours. The smooth experience is what you’ve been waiting for. Improvements made to the body of the tool feature a stronger, reinforced housing. We’ve all dropped our machines a time or two (but never on the paint, right!?) and this new housing helps to protect the insides of our new machine.
Also new on the Rupes BigFoot LHR15 Mark II are rubber inserts INSIDE the tool that improve the handling and provide a better level of comfortability while in use. The new rubber tool rest on top of the machine allows you to set the polisher down pad-up and not contaminate either your pad or the paint you’re working on.
Now to the information we’ve been looking for: the new Rupes BigFoot LHR15 Mark11 motor specs.
The LHR15 Mark11 does feature a higher starting RPM (2500 compared to the original LHR15’s 2000), giving it a little more power and torque to the buffing pad. The 500 watt power draw is the same, but the LHR15 Mark II feels a little more powerful. If you’ve been looking around and wanting to upgrade your current polisher collection, the new Rupes BigFoot LHR15 Mark II is just what you’ve been waiting for.
Technical Specs
RPM Speed: 2500 to 5300
Power: 500 Watts
Weight of Tool: 5.73 lbs.
Orbit Stroke Length: 15 mm
Length of machine: 12.5 inches
The Rupes BigFoot LHR15 MarkII includes a 5 inch backing plate.
On Autogeek.com
On Autogeek.com
Technical Specs
Power: 500 Watts
On Autogeek.com
