Video: RUPES Bigfoot Nano iBrid Short & Long Neck Kits
On Autogeek.com
Rupes Bigfoot Nano iBrid Short Neck Kit - FREE SHIPPING!
Small tool, BIG results!
Since making their official debut in the U.S. market in 2011, Rupes has taken the detailing world by storm by continuously introducing new polishing systems that redefine the detailing industry. This ambitious Italian toolmaker shows no signs of stopping anytime soon! We, along with Rupes, are excited to introduce the all-new Bigfoot Nano with iBrid Technology, another revolutionary polishing system and arguably the biggest step forward the industry has ever witnessed. This compact, lightweight polisher relies on advanced battery technology to enable you to accomplish polishing tasks you never thought possible.
The Rupes Bigfoot Nano with iBrid Technology makes it possible to accomplish the most challenging tasks in detailing, from polishing panels as small as 1-inches wide, to gently removing grease and grime from recessed areas of your car or motorcycle using a series of available brush attachments. Rupes Bigfoot Nano with iBrid Technology sets the new standard for innovation.
Use the iBrid with as small as a 1 inch foam pad!
Rupes ibrid nano makes it possible to polish small body panels with ease
Go where no polisher has gone before!
What exactly is the Rupes Bigfoot Nano with iBrid Technology? First and foremost, the Bigfoot Nano, available in short and long neck versions, enables you to CUT THE CORD and instead rely on Li-ION rechargeable batteries (either configuration includes two batteries). If you forget to charge one battery while the other is being used, you still have the option of plugging in the tool so you can continue to use it.
Secondly, the Rupes Bigfoot Nano with iBrid Technology gives you the option to switch between rotary, 3mm random orbital, and 12mm random orbital actions quickly and easily. In a nutshell, the Rupes Bigfoot Nano accomplishes the same task as 3 other tools, if such individual polishing options even existed in the first place! T
he Rupes Bigfoot Nano with iBrid Technology will forever change the way you detail. The Rupes Bigfoot Nano with iBrid Technology is loaded with advanced features. For example, the Bigfoot Nano includes two Li-ION battery packs and a battery charger. 22-24 minutes is all you will need to charge the battery and each charge provides 30 minutes of run time under full load. The two battery packs allow you to use one in the tool, while charging the other. You will always have a battery charged and ready to switch out.
Changing the battery is as easy as changing a backing plate.
There are two buttons on the base of that unit that release the battery when depressed. Pull the old one out and slide the new one in – it’s that simple! LED indicators on the unit and the battery charger will keep you informed on how much power you have left in the battery pack.
The Rupes Bigfoot Nano with iBrid Technology is available exclusively in a money-saving kit that includes everything you need to get started.
The Rupes Bigfoot Nano iBrid Short Neck Kit includes:
  1. iBrid Nano Short neck
  2. Charger
  3. BIGFOOT Premium Tool Case
  4. Wrench 1-1/4 inch backing plate
  5. 2 inch backing plate
  6. Rotary connector
  7. 3 mm orbit connector
  8. 12 mm orbit connector
  9. AC-DC adapter
  10. 2 Rechargeable power pack
  11. 6 Buffing foam pads - COARSE 1-1/4"
  12. 6 Buffing foam pads - FINE 1-1/4"
  13. 4 Buffing foam pads COARSE 2"
  14. 4 Buffing foam pads FINE 2"
  15. ZEPHIR polishing compound 150 ml COARSE
  16. KERAMIK polishing compound 150 ml FINE
  17. Microfiber towel
  18. Cylinder brush
The Rupes Bigfoot Nano iBrid Long Neck Kit includes:
  1. iBrid Nano Long Neck
  2. Charger
  4. Wrench
  5. 1-1/4 inch backing plate
  6. 2 inch backing plate
  7. Rotary connector
  8. 3 mm orbit connector
  9. 12 mm orbit connector
  10. AC-DC adapter
  11. 2 Rechargeable power pack
  12. 6 Buffing foam pads COARSE
  13. 1-1/4" 6 Buffing foam pads FINE
  14. 1-1/4" 4 Buffing foam pads COARSE
  15. 2" 4 Buffing foam pads FINE 2"
  16. ZEPHIR polishing compound 150 ml COARSE
  17. KERAMIK polishing compound 150 ml FINE
  18. Microfiber towel
  19. Cylinder brush
Made in Italy
1 year warranty
On Autogeek.com
I want the long neck kit so bad but as a hobbyist detailer...how the heck do I talk my wife into spending $600+ on this for me lol?!...I'll figure it out soon I'm sure.
