Video: RUPES LHR 12E Duetto Random Orbital Polisher
On Autogeek.com
Rupes LHR 12E Duetto Random Orbital Polisher - FREE SHIPPING!
Makes vibration and noise a thing of the past!
The Rupes LHR 12E Duetto Random Orbital Polisher is a smooth-operating dual action polisher with the power necessary to remove swirl marks and scratches. Italian-engineered for a perfect finish, the Rupes LHR 12E Duetto Random Orbital Polisher will polish your vehicle’s paint to an extremely high gloss finish without putting unnecessary stress on your arms and back. Rupes polishers are known for their smooth operation, and the LHR 12E Duetto is no different. The Rupes LHR 12E Duetto Random Orbital Polisher and its compact design, powerful 400 watt motor, and massive 12 mm throw will make this versatile car polisher a vital component of every detail.
The Rupes LHR 12E Duetto is the result of countless hours of research and development to design what is arguably the most user-friendly dual action polisher available. Building upon the legendary "Big Foot" moniker set forth by the larger and more powerful LHR 15ES and LHR 21ES, the Duetto continues the Rupes tradition of engineering polishers that have a larger orbit (throw) than anything else on the market. The LHR 12E Duetto, the little brother to the larger LHR 15ES, features a respectable 12 mm orbit, enabling it to be a sander and polisher. The Rupes LHR 12E Duetto includes a 5 inch backing plate designed to be used with 5.5 and 6 inch pads.
Rupes is a company that takes customer feedback seriously, and the LHR 12E Duetto is proof. Designed with the professional detailer in mind, the Rupes LHR 12E Duetto is thoughtfully engineered with superb ergonomics and user-friendly switches and dials. The Rupes LHR 12E Duetto will provide hours of sanding and polishing with minimal user fatigue. The powerful 400 watt motor provides enough juice to keep the pad rotating, making the LHR 12E Duetto capable of removing heavy swirls, water spots, and scratches.
Rupes LHR 12E Duetto removes swirls and water spots without burning paint!
Dual Function: Sanding & Polishing
The Rupes LHR 12E Duetto and its 12 mm orbit can be used with fine grit abrasives to speed up deep correction operations. The tool can then use foam pads and polishing compounds to refine the abrasive scratches and restore a flawless finish.
Ergonomically Perfect
With its non-slip rubber inserts on the front cover, the Rupes LHR 12E Duetto is perfect for all polishing operations in difficult to reach areas. The operator can produce the best results possible with little to no fatigue.
Anti-Spinning Shroud
The dual function anti-spinning shroud is designed to protect the operator against the moving parts and act as a clutch for the backing plate, preventing further stress on the foam polishing pad when it is not in direct contact with the surface.
Design
The attention to detail is not limited to just the innovative and attractive design. The modern lines and exceptional technical quality are combined with a number of details that are the result of meticulous research aimed at achieving maximum operator comfort. The non-slip rubber inserts are numerous and have many functions. In particular, the insert on the machine body is used to support the polisher when placed on a surface.
Electronic Speed Control Module
The speed controller is both practical and easy to use. The speed of the polisher can also be easily adjusted without interrupting the work.
Made in Italy.
1 year warranty.
On Autogeek.com
