Video: RUPES LHR 75E Mini Random Orbital Polisher
On Autogeek.com
Rupes LHR 75E Mini Random Orbital Polisher - FREE SHIPPING!
An easier way to polish small and intricate body panels
The Rupes LHR 75E Mini Random Orbital Polisher is a professional detailer’s dream come true. You will finally be able to remove swirls and scratches from small and intricate body panels with speed and precision. The Rupes LHR 75E Mini Random Orbital Polisher is the first and only mini dual action car polisher that was developed with the professional detailer in mind. The Rupes LHR 75 Mini Random Orbital Polisher and its compact design, powerful 400 watt motor, and massive 12 mm throw will make this versatile car polisher a vital component of every detail.
Rupes, a pioneer in the polishing industry, listened to the requests of professional detailers and car care enthusiasts and created a 3 inch mini polisher that is powerful enough to remove swirls and scratches with ease. The Rupes LHR 75E features a massive 12 mm orbit, giving it the correction ability that professional detailers demand. The powerful 400 watt motor ensures the LHR 75E doesn’t bog down under light loads. The Rupes LHR 75E includes a 3 inch backing plate that is designed for 3, 3.5, and 4 inch pads.
Ergonomically Perfect
With its non-slip rubber inserts on the front cover, the LHR 75E is perfect for all polishing operations in difficult to reach areas. The operator can work in perfect comfort to produce the best possible results. Lined in non-slip rubber, the on/off switch of the Rupes LHR 75E ensures a controlled soft start, giving the operator full control over the tool.
Design
The attention to detail is not limited to just the innovative and attractive design. The modern lines and exceptional technical quality are combined with a number of details that are the result of meticulous research aimed at achieving maximum operator comfort. The non-slip rubber inserts are numerous and have many functions. In particular, the insert on the machine body is used to support the polisher when placed on a surface.
Maximum Flexibility
Thanks to the small diameter backing plate, the Rupes LHR 75E is perfect in polishing applications on small and intricate areas. The small machine dimensions and the 12 mm orbit allow comfortable handling and accuracy in detail polishing.
Electronic Speed Control Module
The speed controller is both practical and easy to use. The speed of the polisher can also be easily adjusted without interrupting the work.
Made in Italy
1 year warranty
On Autogeek.com
