Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Video: RUPES UHS Easy Gloss System
On Autogeek.com
Rupes UHS Easy Gloss System - FREE SHIPPING!
The one-step paint correction system professional detailers have been waiting for!
Rupes is proud to introduce the UHS Easy Gloss System! As the name implies, it is extremely easy to obtain a glossy, swirl-free finish with this time-saving, one-step solution. Designed to remove light to moderate imperfections from all paint systems (including scratch resistant clear coats) while leaving a wax-ready finish, the Rupes UHS Easy Gloss System will quickly become a staple in your arsenal of polishes and pads.
The Rupes UHS Easy Gloss System consists of a UHS Easy Gloss Polishing Compound and UHS Easy Gloss Foam Pads.
The Rupes UHS Easy Gloss System is designed for use with the Rupes Big Foot Random Orbital Polishers, including the Rupes LHR 15ES and Rupes LHR 21ES.
The Rupes UHS Easy Gloss System has been tested and approved for use on all paint systems, including the scratch resistant clear coats found on vehicles manufactured in Europe. Due to the hardness of this type of clear coat, two steps are normally required to remove light to moderate imperfections. That’s not the case with the Rupes UHS Easy Gloss System.
The Rupes UHS Easy Gloss System is a professional detailer’s dream come true. Consisting of just one compound and one foam pad (available in several sizes), the Rupes UHS Easy Gloss System is a true one-step solution for removing light to moderate swirl marks and spider web scratches.
What you see is what you get with Rupes UHS Easy Gloss Polishing Compound, because this body-shop same formula does NOT contain fillers or masking agents. This medium-cut compound has a long working time and wipes off very easily.
Rupes designed UHS Easy Gloss Polishing Compound to be used exclusively with their UHS Easy Gloss Foam Pads. Just like Rupes UHS Easy Gloss Polishing Compound, Rupes UHS Easy Gloss Foam Pads replace the need for two products!
The unique foam used in the UHS Easy Gloss Foam Pads combines the cutting ability of an aggressive foam pad with the finishing ability of a soft foam finishing pad. When used with Rupes UHS Easy Gloss Polishing Compound, Rupes UHS Easy Gloss Foam Pads will not haze or scour the finish, even on softer paint systems!
On Autogeek.com
On Autogeek.com
On Autogeek.com
