Video: The Buff and Shine Uro-Cell Polishing Pad System
The finest European foam technology!
Buff and Shine Uro-Cell Pads are manufactured using a closed cell foam imported from Europe. Known for their durability and great finishing results, European foam pads are quickly becoming the go-to product when detailing professionally. With a lower rate of absorption of chemical, you’re spending less money on product and details will go more smoothly than ever before. Buff and Shine Uro-Cell Pads combine this revolutionary European foam with American ingenuity for the most advanced buffing pads yet!
Perfect for use with water-based compounds and polishes, Buff and Shine Uro-Cell Pads will not absorb product leading to a longer working time, leading to an increase in overall production. Buff and Shine Uro-Cell Pads have a high tensile strength, which means they are more resistant to tears and break-down during use.
On top of this very durable European foam, Buff and Shine also uses a strong adhesive between components, so separation of foam and backing material is not likely, even during extreme use or prolonged use, or during washing. Again, as Buff and Shine Uro-Cell Pads do not absorb product, cleaning them is a breeze.
Buff and Shine Uro-Cell Pads bring forth the amazing correction and polishing power that European foam has to offer - Buff and Shine Uro-Cell Pads expand your paint correcting and polishing potential.
Designed to work especially well with direct drive and dual action orbital polishers, Buff and Shine Uro-Cell Pads are available in three compounding/polishing levels:
Blue Uro-Cell Heavy Cutting Pad
Perfect for heavy paint correction, Buff and Shine Uro-Cell Heavy Cutting Pad will bring out levels of performance from your favorite compound that you have never seen before. With the closed cell foam technology, your cutting ability will be faster and more consistent. Use the Buff and Shine Blue Uro-Cell Heavy Cutting Pad to remove heavy oxidation, swirls and scratches.
Orange Uro-Cell Polishing Pad
Use Buff and Shine Orange Uro-Cell Polishing Pads for light paint correction and polishing. The light cutting ability provides a nice finish after using the Buff and Shine Blue Uro-Cell Heavy Cutting Pad. Use with your favorite swirl remover for quick paint polishing, or with a polish to shine paint to perfection.
Red Uro-Cell Finishing Pad
Perfect for applying your final finish wax or sealant, Buff and Shine Red Uro-Cell Finishing Pad has no cutting ability and finishes your paint to a high shine. Apply last step products like paste waxes, liquid waxes, and paint sealants using the Red Uro-Cell Finishing Pad. 6 inch Buff and Shine Uro-Cell Pads have a 6 inch face diameter with a 5 inch back diameter - a 5 inch backing plate should be used with this pad.
Shop at Buff and Shine Uro-Cell Pads
