Video: The Buff and Shine Uro-Fiber Microfiber Pads
One of the most versatile microfiber pads on the detailing market!
Buff and Shine Uro-Fiber Pads are designed to fully maximize the detailing potential already seen in microfiber pads. With a 25% lower pile than traditional microfiber pads, Buff and Shine Uro-Fiber Pads also feature a blend of two different microfiber grades into just one pad. These two features, never before seen in a microfiber pad, allow you to cut, polish and finish in just one step!
While the black and white fibers found in the Buff and Shine Uro-Fiber Pads lead to an overall attractive appearance, they are for so much more than just looks. With both cutting fibers and polishing fibers blended together into one pad, you are now able to remove light to moderate scratches and swirls, polish to perfection, and buff to a high shine in just one pad! Although, of course, you will need a clean pad for each step.
A blend of both cutting and polishing fibers creates the perfect pad for each step of detailing - in one!
Buff and Shine Uro-Fiber Pads feature a low profile, making them perfect for use with virtually any machine polisher. While Buff and Shine Uro-Fiber Pads were designed for long throw or high action polishers originally, they can successfully be used with any type of polishing machine. With a total thickness of just 3/8”, Buff and Shine Uro-Fiber Pads will conform to the needs of its user.
The foam interface that separate the microfiber pad from the backing plate is made of an open cell foam and allows for working large, flat areas just as well as contours.
Thanks to the chemical and heat resistant adhesive that holds the Buff and Shine Uro-Fiber components together, these microfiber pads excel in durability and hold up under even the toughest polishing sessions. Available in 5 different sizes, you’ll be hard pressed to find a paint polishing or correcting task that CAN’T benefit from a treatment with Buff and Shine Uro-Fiber Pads.
Shop at Buff and Shine Uro-Fiber Pads
Nice to see a video on products. Much appreciated. I do have a 6-pack of these on the way.
Any chance one will be made on the limited edition Lake Country lambswool? Or a review? I think I may not have used it properly.
