washed, WGDGPS, fusion tomorrow, clean off dust with what?
Larry S
Just put another coat of WGDGPS on this morning, going to do a coat of Fusion tomorrow, what should I clean all the dust and pollen off with first?
I have,
Crystal mist
Optimum opti clean
WG DG spritz sealant
Megs final inspection
Which would work best?
Thanks,
Larry
Are u asking what to use to clean ur car before u wax it?
Is the car garaged or parked outside?
I have,
Crystal mist
Optimum opti clean
Thanks,
Larry
Hey Larry,
Since you're applying a coat of Fuzion all you want to do is clean off the dust or pollen so I would think Crystal Mist or Meguiar's Final Inspection would be best.
Optimum Opti-Clean will strip the sealant you've applied and you shouldn't use a spray sealant as a detail spray...
Hey Larry,
bobby you may have confused opt clean with ;power clean. o;pt wont strip but t does have ;polymers that may interferer wth the fjuzon.
my eyboarud s all messed up sorry fjoru the typos
I would feel safest using a waterless wash over a quick detailer. Opti-clean gets my vote. If it was parked in a garage then a QD would probably be fine
opti clean is a waterless wash, so yeah just use that, you don't want to use SPRITZ SEALANT because that needs ANOTHER 12 HOURS to cure before you top it, so best use final inspect to clean light dust, or opti-clean will work also
