Washer mod quistion? The boss
Ryan Bishop
Griots garage package sent me 2 washers for the mod application . Do I use 1 of them and I have for back up or do you use both of the washers?'
2 washer space the backing plate completely from the shroud making it free spinning.
One washer will free it up some but it will still have some drag.
So it all depends on what you want to do.
For more powerful correction use both.
If your still getting adjusted to the machine and aren't that familiar with machine polishing use 1.
The g15 is safer then the g21.
The G21 can create some serious heat with both washers, it is recommended for an experienced enthusiast or professional.
I am un aware of your polishing experiencing, just giving you different scenarios.
If you have any questions about your boss. Don't be afraid to pm me or ask me I would be glad to help.
I have been using the system since it came out!
Enjoy
Enjoy
Awesome, I will. I have worked for a mobile buissness now for a year. So I have pretty good experience with the cars/clients, I have dealt with. I am just getting use to this system. So I will try one for now. Thanks
Use one, if you desire more correction, or more power put the other washer on.
Always check your panels for excess heat, different panels, accept heat in different ways, so always make sure that a certain panel isn't getting excessively hot on a certain speed.
