Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Washing with Diesel?
I get car detailing questions from people via e-mail all the time.
If I can answer without investing a lot of time I will. If I need to write a book to answer all the questions I'll ask the person to join the forum where I prefer to answer questions. The reasons why are,
A: Writing out a detailed answer with step-by-step directions takes time.
B: Writing out a detailed answer where I do the research to locate articles already written to share in the answer takes time.
C: Writing out detailed answers where I include before, during and after pictures takes time.
D: The forum interface works MUCH better for sharing all of the above, especially links and pictures as you can run into all sorts of problems trying to send this type of information in a "reply" inside an e-mail.
E: Typing for one set of eyeballs is not a good use or leverage of typing time.
F: Typeing for one set of eyeballs does not allow many of our knowedgable forum members to also chime in with their ideas, feedback and suggestions.
This is why sometimes you'll see me bring questions sent to me via e-mail directly to the forum. I'll post the person's questions to the forum and then send them the link where they can read the answers. It's a much better use of the company's time.
That leads me to where I'm at now... I recently received a question about coatings. This then turned into the person sharing me the "process" others have taught this person.
In reading the below, I'm aghast at what others have been teaching this guy... I've made the standout recommendations in bold.
Um... I would stop taking direction from whoever is giving you the above instruction as they are not only improper procedures to perform to already THIN factory clearcoat paint but they will lead to you paying for a new paint job. Especially the part about dry sanding with the FLEX DA Polisher. I have to wonder if they actually mean to dry sand with the FLEX 3401 because this would not be called SANDING it would be called GRINDING.
:dunno:
Thank you sir for the answer.
I will tell you what I learn from few detailers here. They taught me
Wash the car properly (diesel wash )
Then dry it properly
After that apply iron remover , wash it off again then dry it properly
After that apply mini SSP clay towel with clay lube wipe it off .
After that new car solvant again wipe it off.
Dry sanding with flex da polisher(1000&1500 no. Paper )
Then wet sanded it with 2000&3000no paper.
Then compound it with heavy cut compound 300/400 (menzerna)
Finish it off with super finish 3800
Then apply new car solvant after that finally ceramic sealant with applicator and do a heat gun .
Leave it for 24 hours .
Please tell me my process is right or am I doing some mistake.
:dunno:
