I have a three filter system. I have one sediment filter and two softener filters. This makes pressure drop quite a bit. I built in a filter bypass so that I can have my normal water pressure. Question. If I fill my wash pail with filtered water and soap, can I wash the entire car at once, then rinse it with the full pressure water, then switch to filtered for the final rinse? Real question is will the soap with filtered water that dries rinse off completely to not leave soap streaks after all of the rinsing.
I ask this as I feel if it is acceptable it should speed up the wash time. Plus I will use less filtered water thus extending my softener filter resin change. Thanks and awaiting your professional responses
Don
Don
