Water Softeners for Detailing
chilly
Our water is super hard and full of minerals
I have looked at the resin type filters but I have also read that they never get anywhere near the life they claim and that recharging them is quite expensive
That leaves a whole house water softener
How well does the water they produce work with all of our chemicals and processes
I personally hate showering with soft water and trying to get the soapy feeling off me but if it means no water spots on the vehicles and better efficiency of soaps and stuff I can live with it
You could use the whole home one for only washing depending how/where you hook it up and it will last a lot longer then using it in the rest of the house if you don't like soft water for other things...
As for recommendations I don't know sorry. I've been thinking of the same thing too for past couple years but never committed to anything :/
I have seen folks with the resin filters and they only use it for the final rinse to make it last longer
We have solar hot water and running softened water through the system would be a very good idea as the panels really lose efficiency as they clog up with minerals
My wife hates the minerals on all the faucets and shower and stuff so I think a whole house system makes sense
I appreciate the input
I'm not a real expert on this topic but here is my understanding nonetheless. I did some research several years ago when I was in your shoes. I ended up building my own RO/DI system.
A water softener will help but it will not eliminate water spots all together. The TDS (Total Dissolved Solids) level of the water coming out of the water softener will be the same as the TDS going in. The difference being the type of dissolved solids.
Your tap water contains dissolved hard minerals such as calcium, magnesium, etc. The water softener replaces those dissolved hard solids in a 1 to 1 ratio with softer sodium.
As for water spots, the sodium spots left behind when using a water softener are not as visible as the harder minerals. They are still there but they are not as bad. And they wipe away much easier. At least that is my experience when I have used softened water.
Wow
That’s an awesome science lesson
I guess I have a lot to think about
What’s an RO/DI system?
I appreciate all the info
RO/DI = Reverse Osmosis/Deionized
The RO is used as a pre treatment for the water prior to running it through the DI resins. The RO process removes approximately 90-95% of the dissolved solids. By doing so the DI resins last much longer.
Thanks
I really have a lot of research to do
Cheers
I was looking at a 4 filter whole house cartridge system similar to the one you are showing that was a partial substitute for a softener
I assume it was a resin system
