I have moved on from the last boat, so I have no pictures of the water spots.
Copy that. Next time.
Here's the deal, defects on anything are either topical or sub-surface and in both instances, they usually require abrading and leveling. The process I show in my boat class and in my boat book have been extremely photo-documented to work. I also taught the process at Mobile Tech Expo with a LIVE demo on the side of a boat.
Boat Detailing Correction and Ceramic Coating Class at MTE 2020
The
FIRST class on Thursday morning is my boat detailing class where I'm going to show LIVE on the side of a REAL boat - how to undo years of oxidation and then install a gel-coat ceramic coating.
Here's the side of a deserted Bayliner boat that will be cut-off and brought to this class.
Just picked up the side of a Bayliner Hull for my Gel-coat Correction and Ceramic Coating Class in Christmas, Florida.
This is the FIRST class on Thursday morning (starts at 8:00am) and the FIRST time a FULL DEMO Gel-Coat Correction and Ceramic Coating class has ever been taught a Mobile Tech Expo.
I just removed the dried-out ancient vinyl graphics. I left a small portion as I'll show how to do this in the class.
Here's process and after results...
The CBEAST!
I used this to machine sand gel-coat. No pad stalling. Fast. No cords.
SONAX Glass Cleaner for a sanding lube. It was close by. Later I switched to water with a little soap.
Mirka Abralon #1000 Grit Sanding Disc plus a Meguiar's 6" foam interface pad. You can see it on the backing plate
Machine sanding
Here's results....
LOOK in the upper left hand corner! That's a Griot's Swirl Finder Light
I'm holding it in my hand and shining onto the BEFORE section.
Now that's a SHOW CAR FINISH on gel-coat!
And the other side - the before condition - ZERO reflection. ZERO SHINE.
What I used...
I will get your book shortly
Alas.... the boat book has been discontinued...
Mike Phillips? How To Detail Boats With Marine 31
It was THE most complicated book I've ever written and I wrote the bulk of it in 10 days from just the grey matter in my knoggin.
Here's the index and I'm pretty sure an entire page is missing...
Right here - Missing picture, which is another page of the index
Many of the topics covered also apply to car detailing so it's a valuable resource even if you don't yet own a boat.
If you're familiar with my writing style in the forum world you'll find the same style of writing in all my how-to books. That is I explain in simple terms how to perform a process plus why you're performing it and it's a combination of including both types of information that helps you to do the best work possible.
I saw someone on this forum share the location of a store in Canada that had a few copies but I don't remember the thread?
