Thanks for the welcome Mike...and thanks for the push to go ahead and get a machine...why not after seeing those pics!!!
I have purchased Chem Guys Water spot remover AND CG Citrus wash from autogeek....
- can I use any of these, or would they be too aggressive to start with
- would I need to use a machine buffer, and could I use one with these products (if they can even be used)
Thanks!
IF the CG Water Spot Remover isn't removing the water post nor the CG Citrus Wash then you'll want to get a Medium Cut or Fine Cut Polish and machine apply with a foam pad.
I think I show something like that in the link I shared above.
IN my how-to book and in the below article I do my best to explain the different categories of abrasive type products.
Word Definitions - Compounds, Polishes, Glazes, Paint Cleaners and Waxes
Here's an example in this thread, the swirl remover we used was a Medium Cut Polish, the finishing polish we used was a Fine Cut Polish.
1939 Lincoln Zephyr - Swirls Removed - Modeled by Nicole
The Major Correction Step
(Page 102 and 103 of my how-to book)
After proving the Pinnacle Advanced Swirl Remover with a polishing pad on a DA Polisher was a combination that worked on this paint system Tommy and I went to work removing the swirls.
The Polishing or Minor Correction Step
(Pages 103 to 105 in my how-to book)
After wiping off any polish residues we moved onto the polishing step to really maximize the gloss, clarity and shine of the clear coat. For this we switched over to Lake Country Black Flat Foam Finishing Pads and continued using DA Polisher....
Here's Tommy using the Meguiar's G110v2 to safely polish the paint to a super high gloss!
How To wax and seal the paint
(Pages 106 to 110 in my how-to book)
Here's Nicole wearing a microfiber glove to hold the Souveran Paste Wax as she applies some wax to the face of Tommy's Lake Country Blue Foam Flat Finishing or Waxing Pad.
Next Tommy and I machine apply the wax to the entire finish...
What's nice about DA Polishers like the PC, Megs and Griot's units is they are light enough and compact in size enough that most people can easily hold them with one hand which makes machine applying the wax fast and easy.
And you're paint can look like this when you're done...
:xyxthumbs:
