Water spots
LAKings22
Member
I'm kind of stuck and can't make up my mind. The car in question is a 14 black Mercedes. Paint was corrected 5 months ago, the hood roof and trunk now have beaded water spots from what I'm assuming is rain since there is no spotting on both sides.
Would you go out and buy 3D eraser or any product similar to it? Or go straight to polishing with polishing pad.
I do have different combos of pads, polishes and compounds I can use to tackle this, I guess I'm just looking to see if something like 3D eraser would be the least aggressive approach.
Thank you.
Sent from my SM-G930V using Tapatalk
Colinite 845 topped with pinnacle Souvern
Thank you.
Why not try a test-spot or two with some polishes you already have? As you mention, start with the least aggressive approach and go from there. You may already have what you need!
That was or still is the plan, but then I came across products like 3D eraser or Optium MDR and figured maybe I can use that to avoid having to remove any clear.
Ok, I see. Well, this car may be a convenient excuse to give those products a try! Do let us know what you finally decided. I'm interested to know.
Kind regards...
Those water spot removing products don’t even work! Lol.
If you read the description for most of them, they state that it’ll remove water spots before they etch your paint... Well yea, so will a Quik Detailer, waterless wash, etc.
You’re better off claying it and if that doesn’t fully remove them follow it up with a light polish, start with a foam finishing pad, it’s usually enough to get the job done.
Actually, I've had good luck with Optimum MDR on "some" types of water spots. What most people don't understand is there are different types of water spots.
In fact, I know a guy.... he wrote an article about the different types...
3 - Types of Water Spots - Type I, Type II and Type III
But over the course of most of my detailing work-life, I've found that when car paint has water spots, at a MINIMUM it will be a Type II Imprint Ring and it will require mechanical polishing to REMOVE SOME PAINT in order to level the surface and thus visually remove the "spot".
I always explain in all my car detailing classes that the reason you start with wheels and tires before washing the body panels of a car is because the WORST type of defect to have to remove out of car paint is water spots. In fact, just shared that for the 3-day class this last weekend. I'm consistent in what I teach.
To LAKings22
BEFORE I ever work on a Mercedes-Benz I first check to see if it has a Ceramiclear paint system. See my article here, the only article like it on the web....
Ceramiclear Paints - Be Careful
Then read this,
Ceramiclear Paint Code Location on Mercedes-Benz
Thank you.
I would try CarPro Spotless first. Wash/clean the panels and remove most of the water but it doesn't have to be dry. Spray on spotless and let dwell. Don't rinse, but rather re-wash those panels and work the product over the surface lightly. Then rinse. I've had great success with it and on occasion I've had to use 2 applications.
If that doesn't work then use 3D Eraser - I use the gel. It will absolutely remove them but it will also remove your LSP and likely on the panels below as you rinse too. Just be aware that you'll need to re coat them.
Have you tried a mild claybar? If a QD, water spot remover, or other chemical product doesn't work, it might be an option to try before using the polisher.
I'm going to do it this weekend. I'll see if the clay alone helps out but more then likely I will be polishing after claying.
To LAKings22
Then read this,
Thanks Mike, I read about Ceramiclear on here when I first started getting into detailing. It's the first things I check for on any Mercedes that I've detailed or anyone that's inquired about having there car detailed.
