Slow cut method (using a random orbital polisher, Final Finish (PO 105FF) and a (White LC CCS foam pad) - this polish is formulated with very finely milled micro diminishing abrasives so they don’t require much to ‘breakdown’ and shouldn’t cause surface marring - Start at speed # 4, move the pad slowly across the area, then speed # 5, without any pressure, when the polish starts to go clear, spray the pad with distilled water, reduce to speed # 4, then spray pad again, increase to speed # 5 and apply pressure. Apply polish at a machine linear speed (MLS) of approximately 0.25 to 0.5-inch per second for each 2-foot x 2-foot panel (hence ‘slow cut’) Burnish paint surface using an ultra-fine (100 ppi) finishing primed foam pad (Black LC CCS) this method is time consuming but the results are well worthwhile.
